Re: What diffs have you put in a 1000?
From Darwin NT
gav i have a 1200 ute diff with bluebird discs should go in under a coupe easy as they have a heap more space then the other models. i did move the mounts but was out by about 5mm ... bugger..... but they can be cut and moved again sure matt could do it for you if your intrested? its all together complete center has been welded (locked) so it would probably be adviseable to get another centre for the street
Posted on: 2009/7/10 1:05
current project 4x4 patrol...
Subject Poster Date
     What diffs have you put in a 1000? Gav 2009/7/9 23:06
       Re: What diffs have you put in a 1000? dattoman_1000 2009/7/9 23:37
       Re: What diffs have you put in a 1000? b310gx 2009/7/10 0:41
       Re: What diffs have you put in a 1000? DatsAndy 2009/7/10 0:57
         Re: What diffs have you put in a 1000? datto1000wagon 2009/7/10 1:05
           Re: What diffs have you put in a 1000? reuby_tuesday 2009/7/10 2:47
             Re: What diffs have you put in a 1000? D 2009/7/10 3:12
               Re: What diffs have you put in a 1000? reuby_tuesday 2009/7/10 3:23
       Re: What diffs have you put in a 1000? Gav 2009/7/10 4:57
       Re: What diffs have you put in a 1000? reuby_tuesday 2009/7/10 6:45
         Re: What diffs have you put in a 1000? perthute 2009/7/10 7:33
       Re: What diffs have you put in a 1000? Gav 2009/7/10 7:37
       Re: What diffs have you put in a 1000? WhiteSedan 2009/7/10 7:42
       Re: What diffs have you put in a 1000? perthute 2009/7/10 7:55
         Re: What diffs have you put in a 1000? WhiteSedan 2009/7/10 8:16
           Re: What diffs have you put in a 1000? perthute 2009/7/10 9:08
             Re: What diffs have you put in a 1000? steveo 2009/7/10 12:29
       Re: What diffs have you put in a 1000? dattoman_1000 2009/7/10 8:19
       Re: What diffs have you put in a 1000? elemental_funk 2009/7/10 12:56
         Re: What diffs have you put in a 1000? steveo 2009/7/10 13:19
           Re: What diffs have you put in a 1000? D 2009/7/11 3:01
