Re: Are all A-series oil pumps same spec?
70 psi is out of specification:
From the 1973 factory service manual:
* Regulator opening pressure: 54-60 psi
* Oil pressure at idle (650 RPM ): 13-17 psi
But 70 psi won't hurt anything.
[Edit] A15 oil pressure specificatin at idle is "More than 11 psi" and at 3000 RPM "54-74 psi". So there is a difference between A12 and A15 oil pump -- the regulator spring is a little different.
Posted on: 2009/7/13 0:46
Edited by ddgonzal on 2009/7/13 1:39:23
Subject Poster Date
     Are all A-series oil pumps same spec? datsonovic 2009/7/12 6:30
       Re: Are all A-series oil pumps same spec? ddgonzal 2009/7/12 7:01
       Re: Are all A-series oil pumps same spec? aidaniel 2009/7/12 11:00
         Re: Are all A-series oil pumps same spec? ddgonzal 2009/7/13 0:46
       Re: Are all A-series oil pumps same spec? datsonovic 2009/7/13 3:16
       Re: Are all A-series oil pumps same spec? benny 2009/7/13 6:10
         Re: Are all A-series oil pumps same spec? ROConnor 2009/7/13 6:17
