Re: Valve spring pressure
Sheesh that's scary stuff....completely worn.
Any pictures?
Well if the followers were not flat (and surface finished) to start with then they certainly would affect the profile of the lobes. The fact that they are now concave would indicate that they had also been contacting more surface area of the lobes (as the lobes began to wear down) so the wear process was magnified and intensified.
Pics would be helpful.
Posted on: 2009/8/19 10:57
Subject Poster Date
     Valve spring pressure B110SSS 2009/8/19 8:12
       Re: Valve spring pressure WhiteSedan 2009/8/19 8:20
       Re: Valve spring pressure bige 2009/8/19 8:44
       Re: Valve spring pressure A14force 2009/8/19 8:45
         Re: Valve spring pressure clyons8 2009/8/19 9:26
           Re: Valve spring pressure B110SSS 2009/8/19 10:48
             Re: Valve spring pressure clyons8 2009/8/19 10:57
               Re: Valve spring pressure ddgonzal 2009/8/19 19:23
                 Re: Valve spring pressure B110SSS 2009/8/20 7:38
                   Re: Valve spring pressure clyons8 2009/8/20 8:21
                     Re: Valve spring pressure B110SSS 2009/8/21 7:43
       Re: Valve spring pressure dazza1200 2009/8/22 4:39
         Re: Valve spring pressure B110SSS 2009/8/22 7:28
