Re: *** 1000 Tie Rod Ends *** B10 fans
From Freo
hmm interesting find, snapped up a pair off the bay, 14mm outers,
turns out every tierod I have here early late or otherwise is 12mm in and out..
from 67 onwards, sedan wagon coupe,
apparently the genuine parts book only lists one,
so the 14mm listings may be a myth,
Posted on: 2009/9/16 15:43
A15 PSI Project Motor
'72 CB750k,
Subject Poster Date
     *** 1000 Tie Rod Ends *** B10 fans Dundee1000 2009/9/11 13:17
       Re: Ok 1000 fans.. perthute 2009/9/11 13:49
         Re: Ok 1000 fans.. matty 2009/9/11 22:55
       Re: Ok 1000 fans.. Weekend1000 2009/9/12 1:21
         Re: Ok 1000 fans.. Dundee1000 2009/9/12 3:13
           Re: Ok 1000 fans.. dattoman_1000 2009/9/12 4:51
             Re: Ok 1000 fans.. jennadat 2009/9/12 7:46
               Re: Ok 1000 fans.. steveo 2009/9/12 8:56
                 Re: Ok 1000 fans.. Dundee1000 2009/9/12 10:28
                   Re: Ok 1000 fans.. dattoman_1000 2009/9/12 11:25
       Re: Ok 1000 fans.. Dundee1000 2009/9/14 16:14
       Re: *** 1000 Tie Rod Ends *** B10 fans perthute 2009/9/14 22:45
       Re: *** 1000 Tie Rod Ends *** B10 fans 1000Coupe 2009/9/15 2:41
         Re: *** 1000 Tie Rod Ends *** B10 fans elemental_funk 2009/9/15 3:16
       Re: *** 1000 Tie Rod Ends *** B10 fans reuby_tuesday 2009/9/15 7:50
         Re: *** 1000 Tie Rod Ends *** B10 fans Dundee1000 2009/9/15 9:29
       Re: *** 1000 Tie Rod Ends *** B10 fans Dundee1000 2009/9/16 15:43
         Re: *** 1000 Tie Rod Ends *** B10 fans steveo 2009/9/22 10:01
           Re: *** 1000 Tie Rod Ends *** B10 fans steveo 2009/9/23 11:20
