hey mate its running blow thru isn't it? ... You need to feed more fuel pressure in then boost pressure otherwise it will start to lean out ... Try setting your boost to 2psi lower then your fuel pressure and give that ago ... If that works then you need a fuel pump that can put out a couple psi more then your boost
Posted on: 2009/9/30 7:57
