Re: Brake light switch striker WA
From sydney australia
Adam, I recommend you take Mark upon his offer, but take the whole brake pedal, because the striker will more than likely break when you try to take it out. the brake pedal is on a shaft that goes from the right hand side of the pedal box & is held in by a 8 mm bolt with a 12 mm head & a big circlip on the left hand side of the shaft. It just takes a bit of patience to put the pedal back, cause it's pretty easy to get the pedal out. Mark, all I can say is 'Spare Shell'. Is the coupe an auto? I need the gearbox crossmember from an auto. That's because I went to the Australian Motorkhana Championships on the weekend & now we're going to put the L18 out of the Sunny coupe into my old Sunny sedan & do Khanacrosses & Motorkhana's next year. I'll just get a Stanza 4 speed, along with the L20b I'm going to fit in the Sunny Coupe. Class D for the long wheel base sedanswas won by an R32 Skyline, of all things.
Posted on: 2009/10/6 10:31
Subject Poster Date
     Brake light switch striker WA Adam12 2009/10/4 22:56
       Re: Brake light switch striker WA b310gx 2009/10/4 23:57
       Re: Brake light switch striker WA datman55 2009/10/6 10:15
       Re: Brake light switch striker WA b310gx 2009/10/6 10:31
         Re: Brake light switch striker WA datman55 2009/10/6 11:51
           Re: Brake light switch striker WA datski620 2009/10/6 12:23
