Re: Heater control valve - 1200 coupe
From Seattle ,WA.
Thanks guys, I have two but they both look like they've been leaking, you know, green hue/crust around the base. I cleaned one up & was thinking about pressure testing it under water to see if it leaks, just haven't done it yet.
I put the whole heater box back together with new foam & cleaned out & tested core so thats the last part I'll need. I know nissan says NLA but has anyone found new ones here ?
How bout you AU guys, can you buy a new one at a parts house over there for a coupe?
Dave, thanks for the offer, I appreciate the gasket you sent as well. I've got to heater boxes as well along with 2 used control valves.
Posted on: 2009/10/27 2:31
Subject Poster Date
     Heater control valve - 1200 coupe edp 2009/10/25 16:36
       Re: Heater control valve - 1200 coupe silvia-specr 2009/10/25 19:40
         Re: Heater control valve - 1200 coupe ddgonzal 2009/10/26 1:14
       Re: Heater control valve - 1200 coupe edp 2009/10/27 2:31
         Re: Heater control valve - 1200 coupe sunny_coupe110 2009/10/29 7:39
