Electric oil pump
From Toowoomba, Qld
Just finished mounting up the A15 in the P312 sedan, now need to fit some sort of remote electric oil pump and filter.
Has anyone used any sort of elec oil pump before and with what results?
by the book the pressure needs to be from 17psi at idle with a relief of 60psi.
as an elec pump will most likely be a constant pressure, does anyone see a problem with a constant 60psi from idle right through.
Anyone have an idea of flow rate required as well?
Cheers
Dave.
Posted on: 2009/10/26 9:56
Subject Poster Date
     Electric oil pump Pendles 2009/10/26 9:56
       Re: Electric oil pump LittleFireyOne 2009/10/26 10:33
         Re: Electric oil pump ddgonzal 2009/10/26 16:02
       Re: Electric oil pump sikyne 2009/10/26 23:35
         Re: Electric oil pump 1000Coupe 2009/10/27 3:09
           Re: Electric oil pump Pendles 2009/10/27 9:19
             Re: Electric oil pump ROConnor 2009/10/27 10:12
               Re: Electric oil pump Pendles 2009/10/27 10:38
                 Re: Electric oil pump ddgonzal 2009/10/28 2:16
