Re: wiring an electronic distributor
From Bathurst - NSW
Yep, you need to remove it, the coil needs all the volts you can give it all the time, the ballast resistor works against this theory. I removed mine when installing my electronic dizzy and new coil.
Posted on: 2009/11/2 8:24
Subject Poster Date
     wiring an electronic distributor Weekend1000 2009/11/2 6:40
       Re: wiring an electronic distributor BRUTE 2009/11/2 8:24
         Re: wiring an electronic distributor steveo 2009/11/2 8:52
       Re: wiring an electronic distributor NHB006 2009/11/3 13:30
       Re: wiring an electronic distributor thedevilshands 2009/11/3 22:18
       Re: wiring an electronic distributor aidaniel 2009/11/3 22:54
         Re: wiring an electronic distributor ddgonzal 2009/11/4 3:14
