Browsing this Thread:
1 Anonymous Users
Bits for sale |
From Newcastle (NSW)
Bits for sale:
- Original A10 engine. Was in running order but with a blown head gasket (had a minor water leak into one cylinder). It needs a new head gasket and a couple head bolts. Easy repair. $200
- Used A10 clutch and flywheel. $20
- Datsun 1000 coupe seats, front and rear. Front is missing the head rests only, rear is complete. Both need reupholstering. $Free
- Datsun 1000 steering column to dash mounting bracket (2-piece). Also have a factory-looking plastic plate that mounts over this and permits the installation of two switches. I haven't seen one of these plates on any other 1000 before. $20
- A10 carbie and original inlet manifold. Good working order. $30
- Datsun 1200 ute brakes (not complete). Includes the backing plates, slave cylinders, mounting hardware, springs, etc. I had to ditch the shoes because they were oil soaked due to a faulty axle seal. Would suit someone looking for a rear brake upgrade without going overboard. $50
- Standard A14 inlet and exhaust manifold. $10.
All located in Maryland NSW (near Newcastle).
Posted on: 2010/1/14 8:29
Racecar spelled backwards is racecar!
