Re: Mythbuster - the need for a brake booster
pedal wont feel good with the booster but better than a small bore diameter master expleiing almost all its fluid with a long pedal travel like mine( if find it ok, its 3/4 to the floor, still bit longer than a stocker which was 1/2 way to floor)
I found moving up to 20mm rear slaves the biggest drama for my pedal travel and feel. keeping 17mm on rear and larger disks up front worked well, but fronts would lock before the rears, now more balance braking but slightly longer pedal travel. Stock twin master cyl
Posted on: 2010/1/25 11:59
Subject Poster Date
     Mythbuster - the need for a brake booster 1200rallycar 2010/1/23 11:52
       Re: Mythbuster - the need for a brake booster ANGE 2010/1/23 12:37
       Re: Mythbuster - the need for a brake booster dattodude 2010/1/23 12:39
       Re: Mythbuster - the need for a brake booster perthute 2010/1/23 12:51
         Re: Mythbuster - the need for a brake booster crzy_1200_ute 2010/1/23 13:18
       Re: Mythbuster - the need for a brake booster Dodgeman 2010/1/23 13:45
         Re: Mythbuster - the need for a brake booster crzy_1200_ute 2010/1/23 13:47
           Re: Mythbuster - the need for a brake booster ddgonzal 2010/1/23 20:12
       Re: Mythbuster - the need for a brake booster Rallytwit 2010/1/23 22:30
         Re: Mythbuster - the need for a brake booster dattoman_1000 2010/1/24 3:20
         Re: Mythbuster - the need for a brake booster Gary_P 2010/1/24 3:24
           Re: Mythbuster - the need for a brake booster ddgonzal 2010/1/24 3:38
       Re: Mythbuster - the need for a brake booster A14force 2010/1/24 5:16
       Re: Mythbuster - the need for a brake booster aidaniel 2010/1/24 9:13
         Re: Mythbuster - the need for a brake booster PIGDOG 2010/1/24 9:48
       Re: Mythbuster - the need for a brake booster ANGE 2010/1/24 11:09
         Re: Mythbuster - the need for a brake booster PIGDOG 2010/1/24 11:35
           Re: Mythbuster - the need for a brake booster Dodgeman 2010/1/24 13:41
       Re: Mythbuster - the need for a brake booster A14force 2010/1/25 8:09
         Re: Mythbuster - the need for a brake booster 1200rallycar 2010/1/25 8:15
       Re: Mythbuster - the need for a brake booster bert 2010/1/25 8:31
       Re: Mythbuster - the need for a brake booster Anonymous 2010/1/25 11:59
       Re: Mythbuster - the need for a brake booster ddgonzal 2010/1/25 19:26
       Re: Mythbuster - the need for a brake booster Anonymous 2010/1/25 21:01
         Re: Mythbuster - the need for a brake booster ddgonzal 2010/1/25 21:20
           Re: Mythbuster - the need for a brake booster DISCO_BOB 2010/1/26 9:40
