Browsing this Thread:
1 Anonymous Users
210 & 1200 parts swapping.... |
From Seattle ,WA.
will a stock steering wheel from a 1980 210 fit a 1200 steer shaft splines? Also, when swapping the rearend center, H150 into the H145 housing aside from the 2MM shim I assume I need the axles & backing plates as well, are the wheel bearings on the axles & the seals in the axle housing the same as the 1200 ?
I went a to a great deal of trouble finding axle bearings for the H145 axles & it'd be nice if they swapped directly into the H150 center - anyone have a specific ABC plan for this type of swap? I know its covered a bit in the wiki but it didn't seemed to answer these questions unless I missed it.
Thanks ,Evan
Posted on: 2010/1/23 18:46
