Re: Need Help...Timing Chain Alignment
Yes those instructions sound wrong. At TDC, the crank won't line up as shown in the photo.
Use the procedure listed in your repair manual. Sometimes a new chain will also come with instructions.
Also be sure to check the sprocket height and put the correct shims in, per the repair manual.
Posted on: 2010/2/6 19:06
Subject Poster Date
     Need Help...Timing Chain Alignment bituten 2010/2/6 14:46
       Re: Need Help...Timing Chain Alignment ddgonzal 2010/2/6 19:06
       Re: Need Help...Timing Chain Alignment A14force 2010/2/6 23:46
         Re: Need Help...Timing Chain Alignment LittleFireyOne 2010/2/7 1:48
           Re: Need Help...Timing Chain Alignment Mildman 2010/2/7 1:54
             Re: Need Help...Timing Chain Alignment ddgonzal 2010/2/7 2:09
             Re: Need Help...Timing Chain Alignment Mildman 2010/2/9 11:02
       Re: Need Help...Timing Chain Alignment dazza1200 2010/2/7 6:01
       Re: Need Help...Timing Chain Alignment bituten 2010/2/7 7:08
       Re: Need Help...Timing Chain Alignment bituten 2010/2/8 2:56
         Re: Need Help...Timing Chain Alignment ddgonzal 2010/2/8 3:47
       Re: Need Help...Timing Chain Alignment bituten 2010/2/9 6:34
         Re: Need Help...Timing Chain Alignment ddgonzal 2010/2/9 7:13
       Re: Need Help...Timing Chain Alignment bituten 2010/2/9 7:49
         Re: Need Help...Timing Chain Alignment ddgonzal 2010/2/9 7:56
       Re: Need Help...Timing Chain Alignment bituten 2010/2/9 8:11
