Re: Rocker Cover breather --> Block breather..what will happen?
finally i found the problem... the conrod burn duh.. the engine oil empty.. ( leaking i guess ) so will it be other thing like bearing, valve, piston n etc to be problem as well ??
so will it better i rebuild this a15 or find another a15 engine i think it will cost alot to rebuild rite ???
Posted on: 2010/3/2 3:02
Subject Poster Date
     Rocker Cover breather --> Block breather..what will happen? bituten 2010/2/19 9:29
       Re: Rocker Cover breather --> Block breather..what will happen? racetech 2010/2/19 9:42
         Re: Rocker Cover breather --> Block breather..what will happen? dattoman_1000 2010/2/19 11:19
           Re: Rocker Cover breather --> Block breather..what will happen? scott77 2010/2/19 11:33
       Re: Rocker Cover breather --> Block breather..what will happen? dattodude 2010/2/19 11:42
         Re: Rocker Cover breather --> Block breather..what will happen? ddgonzal 2010/2/19 20:54
       Re: Rocker Cover breather --> Block breather..what will happen? Rezlo 2010/2/20 7:13
         Re: Rocker Cover breather --> Block breather..what will happen? A14force 2010/2/20 21:41
       Re: Rocker Cover breather --> Block breather..what will happen? dattosans 2010/2/21 2:09
       Re: Rocker Cover breather --> Block breather..what will happen? demontweaks 2010/2/22 12:35
         Re: Rocker Cover breather --> Block breather..what will happen? ddgonzal 2010/2/22 21:29
       Re: Rocker Cover breather --> Block breather..what will happen? dattosans 2010/3/2 3:02
