Re: Who runs a high Compression-Ratio and what fuel do you use?
Cheers FDS.
Turns out I can't even get E85 [which is what I think would work] here in SA. I spoke to someone who works in the petroleum industry and E85 is currently only available [via big-name agents like BP, Shel etc] in VIC and NSW.
Unless I run BP Race Fuel which is rated at 110. I don't think that's very practical though.
The highest ethanol blend available via pump is E10 and maybe E20 here in SA, unless I get ahold of some to mix in myself.
Posted on: 2010/3/4 10:57
Subject Poster Date
     Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 6:25
       Re: Who runs a high Compression-Ratio and what fuel do you use? Dundee1000 2010/3/4 6:55
         Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 7:03
           Re: Who runs a high Compression-Ratio and what fuel do you use? ROConnor 2010/3/4 7:18
             Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 7:37
       Re: Who runs a high Compression-Ratio and what fuel do you use? Anonymous 2010/3/4 9:25
       Re: Who runs a high Compression-Ratio and what fuel do you use? supafatto 2010/3/4 9:33
       Re: Who runs a high Compression-Ratio and what fuel do you use? 2QK4U 2010/3/4 9:37
         Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 9:43
       Re: Who runs a high Compression-Ratio and what fuel do you use? supafatto 2010/3/4 9:53
         Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 10:05
           Re: Who runs a high Compression-Ratio and what fuel do you use? Fandatstick 2010/3/4 10:44
             Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 10:57
               Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 11:19
                 Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 11:22
       Re: Who runs a high Compression-Ratio and what fuel do you use? Fandatstick 2010/3/4 10:40
       Re: Who runs a high Compression-Ratio and what fuel do you use? sikyne 2010/3/4 11:08
       Re: Who runs a high Compression-Ratio and what fuel do you use? sikyne 2010/3/4 11:31
         Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 11:43
           Re: Who runs a high Compression-Ratio and what fuel do you use? D 2010/3/4 12:29
             Re: Who runs a high Compression-Ratio and what fuel do you use? ddgonzal 2010/3/4 20:38
       Re: Who runs a high Compression-Ratio and what fuel do you use? Anonymous 2010/3/4 20:45
         Re: Who runs a high Compression-Ratio and what fuel do you use? Anonymous 2010/3/4 20:47
           Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/4 21:02
       Re: Who runs a high Compression-Ratio and what fuel do you use? bert 2010/3/4 20:58
       Re: Who runs a high Compression-Ratio and what fuel do you use? sikyne 2010/3/4 21:36
       Re: Who runs a high Compression-Ratio and what fuel do you use? Fenix_Longbow 2010/3/5 21:00
         Re: Who runs a high Compression-Ratio and what fuel do you use? ddgonzal 2010/3/5 22:39
           Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/5 22:56
       Re: Who runs a high Compression-Ratio and what fuel do you use? datto_mog 2010/3/6 1:14
         Re: Who runs a high Compression-Ratio and what fuel do you use? Fenix_Longbow 2010/3/6 4:08
           Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/3/6 6:54
             Re: Who runs a high Compression-Ratio and what fuel do you use? Rallytwit 2010/3/7 4:43
       Re: Who runs a high Compression-Ratio and what fuel do you use? lamb_daiquiri 2010/6/7 13:52
       Re: Who runs a high Compression-Ratio and what fuel do you use? jmac 2010/6/7 16:13
       Re: Who runs a high Compression-Ratio and what fuel do you use? dattoman_1000 2010/6/8 12:04
       Re: Who runs a high Compression-Ratio and what fuel do you use? jmac 2010/6/8 14:20
         Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2010/6/8 15:45
       Re: Who runs a high Compression-Ratio and what fuel do you use? lamb_daiquiri 2011/9/23 9:55
       Re: Who runs a high Compression-Ratio and what fuel do you use? clyons8 2011/9/23 10:14
       Re: Who runs a high Compression-Ratio and what fuel do you use? bige 2011/9/23 10:39
       Re: Who runs a high Compression-Ratio and what fuel do you use? MHdat 2011/9/23 13:21
       Re: Who runs a high Compression-Ratio and what fuel do you use? bige 2011/9/23 13:58
       Re: Who runs a high Compression-Ratio and what fuel do you use? MHdat 2011/9/23 14:47
