B110 Understeer while cornering!!! Arghhh
From Malaysia
Lately my B110 understeer badly on wet road.
Slight decrease in dry road.
Front Wheel spec:
Hayashi 13x5.5jj et10 185/60R13 + 10mm spacer
Rear Wheel spec :
12x4.5jj et22 155/80R12
Front Suspension spec:
Std absorber(change to higher visco oil)
Custom Lowered n Stiffer spring
Rear Suspension spec :
WELD DIFFERENTIAL
STD Leaf Spring
Merc 123 Absorber (Rough Ride)
Alignment specs:
Front Left Front Right
Toe = 0.3deg 0.4deg
Camber = -2.5deg -2.5deg
Setback= 27.5mm 32.5mm
Caster = 3.8deg 2.8deg
KPI = 9deg 9deg
Max Right= 43deg 35deg
Max Left = 33.5deg 42deg
I already tried to increase/decrease frt/rr tyre pressure but still getting hard understeer..
Wat seems to b the problem???
Posted on: 2010/4/12 14:58
Subject Poster Date
     B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/12 14:58
       Re: B110 Understeer while cornering!!! Arghhh ANGE 2010/4/12 21:41
       Re: B110 Understeer while cornering!!! Arghhh dattodude 2010/4/12 22:23
         Re: B110 Understeer while cornering!!! Arghhh benny 2010/4/12 23:12
           Re: B110 Understeer while cornering! Dodgeman 2010/4/16 13:30
             Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 14:39
       Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/13 5:08
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/13 13:14
           Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/14 2:26
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/14 10:54
         Re: B110 Understeer while cornering!!! Arghhh racinaround 2010/4/14 12:55
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/14 13:31
       Re: B110 Understeer while cornering!!! Arghhh jmac 2010/4/14 21:00
         Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/16 2:59
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/16 3:38
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 6:25
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 6:34
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/16 10:04
       Re: B110 Understeer while cornering!!! Arghhh jmac 2010/4/16 14:58
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 15:39
           Re: B110 Understeer while cornering!!! Arghhh estyre 2010/4/16 16:12
             Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/17 1:33
               Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/17 9:30
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/22 15:26
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/22 15:32
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/6/30 7:18
         Re: B110 Understeer while cornering!!! Arghhh benny 2010/6/30 7:22
           Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/6/30 7:33
