Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank
From South-Africa,Pretoria
i have decided to do so awell, wont know if i dont try. will keep you posted.
Posted on: 2010/5/4 12:01
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
Subject Poster Date
     Anyone used cut down (2.5mm)A14 pisons on an A15 crank Clive 2010/4/30 12:27
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank dattoman_1000 2010/4/30 15:00
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank LAGWAGON 2010/4/30 15:18
         Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank estyre 2010/4/30 15:29
           Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank benny 2010/4/30 23:17
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank datoboy1982 2010/5/3 7:49
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Clive 2010/5/4 12:01
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Aegis 2010/5/4 12:25
         Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Dundee1000 2010/5/4 12:44
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank datoboy1982 2010/5/6 9:05
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Clive 2010/5/16 21:40
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Dat82 2010/5/17 0:26
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/1 10:36
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank racetech 2010/12/1 11:21
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank bige 2010/12/1 12:08
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank jmac 2010/12/1 16:37
         Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Datsun100ATurbo 2010/12/1 18:53
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank bert 2010/12/2 3:33
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/2 7:08
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/2 9:44
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/3 7:54
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank clyons8 2010/12/3 7:57
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank Lemonhead 2010/12/3 8:12
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/3 8:16
         Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank clyons8 2010/12/3 8:23
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/3 8:19
       Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank lamb_daiquiri 2010/12/3 8:27
         Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank clyons8 2010/12/3 8:56
