Re: 120y coupe rear axle
how would i go about replacing this diff center, and what would i be able to upgrade it to a later model (which bolts straight in?)
do you just take the wheels off, loosen the drum bolts?, and pull the drum out a bit then loosen the pumpkin and replace?
or can i get away with just pulling the pumpkin out and replacing it
i've never worked with differentials so i don't know
Posted on: 2010/5/5 15:47
Subject Poster Date
     120y coupe rear axle davidbil 2010/5/5 4:26
       Re: 120y coupe rear axle LittleFireyOne 2010/5/5 8:52
       Re: 120y coupe rear axle davidbil 2010/5/5 14:50
         Re: 120y coupe rear axle LittleFireyOne 2010/5/5 15:25
       Re: 120y coupe rear axle davidbil 2010/5/5 15:47
       Re: 120y coupe rear axle bert 2010/5/5 22:28
       Re: 120y coupe rear axle 120Ylover 2010/5/17 20:48
