Re: $15000 on motor
Factor in labour guys... that is where most of the money would have been spent. Speedflow fitting cost about $50 a piece unless you know sumone... :P
Id believe that... There is actually nothing wrong a cast manifold, in fact its better than any steel or thin walled turbo manifold as what is one of the key things which drives a turbo...? Heat... Not even a ceramic coated manifold and a turbo beanie can retain as much heat as wat a cast manifold can hold. Only real downside is the weight of the damn thing...
Posted on: 2010/5/17 8:14
Subject Poster Date
     $15000 on motor hotrocket 2010/5/16 9:29
       Re: $15000 on motor cracka50 2010/5/16 9:37
       Re: $15000 on motor davidbil 2010/5/16 9:38
       Re: $15000 on motor davidbil 2010/5/16 9:39
         Re: $15000 on motor sikyne 2010/5/16 9:46
       Re: $15000 on motor levey 2010/5/16 9:48
       Re: $15000 on motor ssskiwi 2010/5/16 10:13
         Re: $15000 on motor shaun 2010/5/16 11:12
       Re: $15000 on motor supafatto 2010/5/16 11:23
         Re: $15000 on motor Jordan 2010/5/16 12:45
           Re: $15000 on motor clyons8 2010/5/16 12:53
       Re: $15000 on motor supafatto 2010/5/16 13:15
         Re: $15000 on motor john_13961 2010/5/16 14:35
       Re: $15000 on motor bailz 2010/5/16 15:10
         Re: $15000 on motor dattoman_1000 2010/5/16 15:36
       Re: $15000 on motor PIGDOG 2010/5/17 1:26
         Re: $15000 on motor D 2010/5/17 4:44
           Re: $15000 on motor Rallytwit 2010/5/17 5:13
           Re: $15000 on motor D 2010/5/17 11:33
       Re: $15000 on motor Fenix_Longbow 2010/5/17 8:14
