Re: AUDI 50 CLUTCH INTO 63A GEARBOX??
But the spline size and diameter are nothing like the A series
So an L clutch isn't much good to you either
A-series engines don't have splines.
The 63A 5-speed for A-series engine uses the same input shaft diameter and splines as 63A 5-speed for L-series engine. So you need the same clutch disk as fitted to the L14 engine. It is 180 mm diameter and so takes a standard A14/A15 clutch pressure plate.
Or you can redrill the A12 flywheel to fit the more common L16 clutch disc and pressure plate (200 mm diameter)
Posted on: 2010/6/15 17:15
Subject Poster Date
     AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/14 15:12
       Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? datski620 2010/6/14 15:20
         Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/14 15:26
           Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? ddgonzal 2010/6/14 17:32
             Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/14 17:45
               Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? ddgonzal 2010/6/15 0:07
                 Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? dattoman_1000 2010/6/15 0:25
                   Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? ddgonzal 2010/6/15 0:28
       Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? D 2010/6/15 1:08
       Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/15 10:02
         Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? PIGDOG 2010/6/15 11:17
         Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? ddgonzal 2010/6/16 5:35
       Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/15 11:58
         Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? dattoman_1000 2010/6/15 13:12
           Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? Bandit_blues 2010/6/15 14:19
             Re: AUDI 50 CLUTCH INTO 63A GEARBOX?? ddgonzal 2010/6/15 17:15
