A14 Carb Problem
From Toowoomba
Hi All,
I have a 1200 ute with A14.. stock carb with crap removed..
I think I have an idle jet problem ...not sure ..
When I start the engine cold it seems to take alot of turning and then when it does fire it coughs and splutters and runs rough for about 1 min and then runs fine, idles well and everything, starts first hit again.
Its like something just switches and allows the fuel to flow and it runs like a dream..
I've tried following idle mix adjustment guides etc ie screww right in then out 2 turns, then adjust to highest revs. but then when starting from cold it never runs. I have to back the idel mix out about 8 turns to get it to idle...
Choke also doesn't seem to work...just floods it..
Any help would be appreciated..
Posted on: 2010/6/20 11:34
Subject Poster Date
     A14 Carb Problem real_lifer 2010/6/20 11:34
       Re: A14 Carb Problem ssskiwi 2010/6/20 11:40
