Re: 1200 a15 Custom Manifold Clearance
From Adelaide
Right, I'm with you now. Do you happen to know what the angle is? A mitre of roughly 8 degrees or less wont matter much if the cross secion is consistant before and after. I've been hoping to pick up a second hand head cheap to play with, I guess I'll look up that section on the forum and have a guesstimate, the angle will mean the port cross secion is less than the flange face area. It's not too hard to project the profile onto a plane at an angle though. My maths is pretty good.
I do remember seeing another custom manifold that bent over the rocker cover made of stainless on the forum which is a good reference. In any case it's early days design wise.
Posted on: 2010/7/17 3:38
Subject Poster Date
     1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/6/23 1:53
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/17 0:01
         Re: 1200 a15 Custom Manifold Clearance clyons8 2010/7/17 2:13
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/17 3:09
         Re: 1200 a15 Custom Manifold Clearance clyons8 2010/7/17 3:29
           Re: 1200 a15 Custom Manifold Clearance clyons8 2010/7/17 3:44
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/17 3:38
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/17 3:56
       Re: 1200 a15 Custom Manifold Clearance sikyne 2010/7/17 6:43
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/17 7:01
       Re: 1200 a15 Custom Manifold Clearance lamb_daiquiri 2010/7/18 7:29
