Re: castor explained..... please
From Melbourne, Australia
from wiki
The pivot points of the steering are angled such that a line drawn through them intersects the road surface slightly ahead of the contact point of the wheel. The purpose of this is to provide a degree of self-centering for the steering - the wheel casters around so as to trail behind the axis of steering. This makes a car easier to drive and improves its directional stability (reducing its tendency to wander). Excessive caster angle will make the steering heavier and less responsive, although, in racing, large caster angles are used to improve camber gain in cornering. Caster angles over 10 degrees with radial tires are common. Power steering is usually necessary to overcome the jacking effect from the high caster angle.
http://en.wikipedia.org/wiki/Caster_angle
Posted on: 2010/6/24 9:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     castor explained..... please ANGE 2010/6/24 8:38
       Re: castor explained..... please ROConnor 2010/6/24 8:42
         Re: castor explained..... please benny 2010/6/24 8:50
           Re: castor explained..... please benny 2010/6/24 9:05
             Re: castor explained..... please ANGE 2010/6/24 9:09
               Re: castor explained..... please 1200rallycar 2010/6/24 9:12
             Re: castor explained..... please ROConnor 2010/6/24 9:11
               Re: castor explained..... please benny 2010/6/24 9:17
             Re: castor explained..... please benny 2010/6/24 9:13
         Re: castor explained..... please ANGE 2010/6/24 8:51
           Re: castor explained..... please Anonymous 2010/6/24 9:04
       Re: castor explained..... please jmac 2010/6/24 15:10
       Re: castor explained..... please PIGDOG 2010/6/24 22:54
       Re: castor explained..... please ddgonzal 2010/6/24 23:18
         Re: castor explained..... please ddgonzal 2010/6/25 2:50
       Re: castor explained..... please benny 2010/6/26 11:44
         Re: castor explained..... please Anonymous 2010/6/26 15:31
           Re: castor explained..... please benny 2010/6/27 0:16
       Re: castor explained..... please A14force 2010/6/27 1:43
       Re: castor explained..... please racinaround 2010/6/27 3:35
         Re: castor explained..... please ssskiwi 2010/6/27 4:12
           Re: castor explained..... please ddgonzal 2010/6/27 4:38
             Re: castor explained..... please wards 2010/6/27 8:26
       Re: castor explained..... please Datsss 2010/6/29 5:05
