Re-Wiring the 1k
From Brisbane
I plan on re-wiring the car this weekend and im a little confused ... My brother has bought cable, but i think its a little too "thick" ...
We went by the fuse box which says 15A, 20A and 30A ... I have had trouble finding cable to suit so we bought 25A and 50A (assuming that as long as its fused correctly we should be fine) ...
However i was looking under the dash, and i really dont see the point in running 25A (i think 5mm) cable for all the switches etc under the dash ... I understand running the thicker wire for the Headlights and higher current items, but for some of the others im a little unsure ...
Can someone point me in the right direction. Should i just run the thicker cabling for a select few items and thinner for the rest?
If so how thin can/should i go?
I hope the above makes sense ...
Hamza
Posted on: 2010/7/8 11:53
Subject Poster Date
     Re-Wiring the 1k HamzaLH 2010/7/8 11:53
       Re: Re-Wiring the 1k Dundee1000 2010/7/8 11:55
       Re: Re-Wiring the 1k clyons8 2010/7/8 15:10
         Re: Re-Wiring the 1k ddgonzal 2010/7/8 19:39
       Re: Re-Wiring the 1k HamzaLH 2010/7/9 0:17
         Re: Re-Wiring the 1k ddgonzal 2010/7/9 2:35
       Re: Re-Wiring the 1k HamzaLH 2010/7/9 2:52
