Re: Crankcase Ventilation and Rocker Cover Breather Lines
From mandurah
i thought all A series motors blow smoke haha ,i noticed that when i started my A12 on the ground with no rocker cover or crankcase ventalation hooked up it tended to get abit smokey
could it also be the oil might need changing aswell as the pcv valve being installed ?
Posted on: 2010/7/16 13:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Subject Poster Date
     Crankcase Ventilation and Rocker Cover Breather Lines clyons8 2010/7/16 9:57
       Re: Crankcase Ventilation and Rocker Cover Breather Lines benny 2010/7/16 10:14
       Re: Crankcase Ventilation and Rocker Cover Breather Lines bige 2010/7/16 10:15
       Re: Crankcase Ventilation and Rocker Cover Breather Lines bige 2010/7/16 10:16
       Re: Crankcase Ventilation and Rocker Cover Breather Lines clyons8 2010/7/16 10:24
       Re: Crankcase Ventilation and Rocker Cover Breather Lines bige 2010/7/16 10:41
       Re: Crankcase Ventilation and Rocker Cover Breather Lines Anonymous 2010/7/16 10:47
         Re: Crankcase Ventilation and Rocker Cover Breather Lines clyons8 2010/7/16 10:57
           Re: Crankcase Ventilation and Rocker Cover Breather Lines Dundee1000 2010/7/16 13:19
             Re: Crankcase Ventilation and Rocker Cover Breather Lines clyons8 2010/7/16 13:27
       Re: Crankcase Ventilation and Rocker Cover Breather Lines levey 2010/7/16 13:36
       Re: Crankcase Ventilation and Rocker Cover Breather Lines estyre 2010/7/16 13:43
       Re: Crankcase Ventilation and Rocker Cover Breather Lines bige 2010/7/16 17:10
       Re: Crankcase Ventilation and Rocker Cover Breather Lines clyons8 2010/7/17 0:52
       Re: Crankcase Ventilation and Rocker Cover Breather Lines bige 2010/7/17 1:32
       Re: Crankcase Ventilation and Rocker Cover Breather Lines LittleFireyOne 2010/7/17 7:04
