Re: A12/A14/A15 Ajustable cam pully/ Vernier pully
From sydney.nsw
if your playing with cam timing and wish to change it a few times, you are best to buy the custom made timing case as well.instead of pulling the sump and timing case off every time you what to change the cam timing.you only need to set cam timing once(refer to your cam specs), but you can play if u wish (comes back to cost of adjustable gear and timing case)if you can get it right the fist time its all good. cheers ernie
Posted on: 2010/7/19 10:52
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Subject Poster Date
     A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 10:25
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully clyons8 2010/7/19 10:29
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 10:38
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/19 10:52
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 11:45
           Re: A12/A14/A15 Ajustable cam pully/ Vernier pully dattoman_1000 2010/7/19 12:06
             Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 12:25
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully racetech 2010/7/19 12:39
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully clyons8 2010/7/19 12:44
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/20 6:43
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/20 6:58
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/20 7:06
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/20 7:48
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully A14force 2010/7/20 9:40
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/21 7:24
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully A15_Tweaker 2010/7/21 9:38
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Rezlo 2010/7/21 19:31
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/23 6:26
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Rezlo 2010/7/23 14:21
