Re: Distributor 180deg out?
Thanks for the help mate.
Iv already adjusted the ralitive timing by moving the leads, but i dont have enough movement in the mount/ Stay bolt to allow small adjustments in timing.
Ie. With cyl1 at 5deg before tdc i cannot adjust the points enough that the points are just opening, this is happing around 10deg before tdc.
Posted on: 2010/10/19 6:25
Subject Poster Date
     Distributor 180deg out? Morris1200 2010/10/18 23:14
       Re: Distributor 180deg out? ddgonzal 2010/10/19 2:37
         Re: Distributor 180deg out? Morris1200 2010/10/19 6:25
           Re: Distributor 180deg out? ddgonzal 2010/10/19 7:26
       Re: Distributor 180deg out? SunnyDaze 2010/10/19 7:56
         Re: Distributor 180deg out? Morris1200 2010/10/19 8:49
           Re: Distributor 180deg out? ssskiwi 2010/10/19 10:07
