Re: 60A reverse switch ???
From Beautiful Sunny (sic) Melbourne
You'll never fit another switch in without modifying the tunnel. I cut the switch off leaving only about 3 mm of protrusion out of the side of the gearbox - it just cleared in the tunnel.
You could put a switch with a little pilot light on the dash, that's an easy solution. One asdvantage of doing that is that you can flash at people behind you who are annoying you
Posted on: 2010/11/22 6:41
Subject Poster Date
     60A reverse switch ??? - Update edp 2010/11/22 5:08
       Re: 60A reverse switch ??? denuto 2010/11/22 6:41
         Re: 60A reverse switch ??? benny 2010/11/22 8:07
       Re: 60A reverse switch ??? levey 2010/11/22 10:03
       Re: 60A reverse switch ??? edp 2010/11/22 16:32
       Re: 60A reverse switch ??? - Update edp 2010/11/23 4:39
       Re: 60A reverse switch ??? - Update clyons8 2010/11/23 5:06
       Re: 60A reverse switch ??? - Update edp 2010/11/23 16:13
         Re: 60A reverse switch ??? - Update Weekend1000 2010/11/24 3:00
       Re: 60A reverse switch ??? - Update Weekend1000 2010/11/27 11:55
       Re: 60A reverse switch ??? - Update edp 2010/11/27 19:13
