Re: can i use a hydrulic clutch on a datsun a12 gearbox
From Perth WA AUS
I think you can, pretty sure the bell housings are the same. Just need to cut a hole for the hydro setup (nissan has marked the spot on the gearbox as a raised oval shape) and dril and tap holes for the slave cylinder mounting points.
Posted on: 2010/11/23 11:53
Datsun 1200 2Dr sedan.
Subject Poster Date
     can i use a hydrulic clutch on a datsun a12 gearbox datto13b 2010/11/23 11:19
       Re: can i use a hydrulic clutch on a datsun a12 gearbox levey 2010/11/23 11:53
