Re: will these wheels fit 1200 ute?
Quite a regular
From SA
i hav 13" x 7 watanabe's on the front of my ute.. and my centre bore is 65mm and i had trouble getting the wheels to sit right. so i put some 6mm slip on spacers and they are all good :)
so im guessing you should be ok with a 75mm centre bore.. i suggest you try b4 you buy.. and if you use spacers put some lock tight on your studs just 2 be safe. or get longer studs.
hope this was the answer u where looking for.. good luck. :)
Posted on: 2011/1/14 5:13
Subject Poster Date
     will these wheels fit 1200 ute? penfold88 2011/1/14 4:22
       Re: will these wheels fit 1200 ute? willzdatto 2011/1/14 4:39
         Re: will these wheels fit 1200 ute? afican_kid86 2011/1/14 5:13
