Browsing this Thread:
1 Anonymous Users
rear brake cyl |
hi all,
last time i put larger rear brake cyls in my h150, i put 19mm compared to 17mm ones from standard.
i noticed the fronts locked up way more easily that the rears were to engage
im wanting to swap back to 17mm ones but cant find the right part numbers. i know h150 are from 120y and the bw ones are different. the h150 are same as h145 and h165 im pretty sure.
any one got the part numbers for them? i just want to get more brake balance back for my engeieening test. need to do 16 continious brakes to stop from 60kmh with minimal fade (within reason/specs).
changing to a larger brake master is not necessary with the 200b set up up front. just needs more balance towards the rear.
Posted on: 2011/2/12 10:04
