Re: How would you fix this?
From Snohomish, WA USA
Depending how deep the ripples are you can skip bonding filler and use fiberglass filler which is more durable. Its the purple stuff in the gallon can. The proper way is to cut the fender out and weld a new one in. Fast and easy, use fiberglass filler.
Posted on: 2011/2/26 18:03
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     How would you fix this? AgentWright007 2011/2/26 17:09
       Re: How would you fix this? ddgonzal 2011/2/26 18:01
       Re: How would you fix this? datsa73 2011/2/26 18:03
       Re: How would you fix this? AgentWright007 2011/2/26 19:26
