Browsing this Thread:
1 Anonymous Users
Re: 1200 ute brakes |
From Melbourne, Australia
The best thing to do is Google this subject. Most of the returns will actually be from this forum. Write down or copy all of the different options you read about into a MS Word file so you can refer back to it. It's easy to get side tracked while you're doing it. There are hundreds of different options that people have been tried but it all gets a bit confusing after a while! If you're going to change your rotors the likeliood is you will eed to change calipers as the standards won't be wide enough to accept the wider vented discs. I can't give any advice of 120Y struts unfortunately as all my research has been into Stanza struts. I'm not sure where you're located but Hoppers Stoppers here in Melbourne are very good at doing upgrades to standard struts.
Posted on: 2011/3/2 23:29
Current Fleet- 1996 R33 GT-R Skyline 1996 Falcon XH XR6 Ute 1977 Datsun 1200 Ute A14 (Fergus) 2012 VW Passat TDI Wagon
