Re: is it easy to turn a auto datsun 1200 coupe into a manual
From Melbourne, Australia
pretty much yep!
just get the pedals, box, clutch sutff, spigot bush, tailshaft, clutch cable and swap it all over
need to get the part that support the clutch cable where it goes through the firewall and drill the holes for that. and sort out a gear boot to seal the hole in the floor around the gear shifter,
oh yeah... and probably the toughest part is the gearbox cross member. as the auto and manual cars have mounts in different places you need to adapt one or the other to suit the new locations. or go for a custom drilled through the floor with plates job
Posted on: 2011/3/18 10:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     is it easy to turn a auto datsun 1200 coupe into a manual datscrazzzzzy 2011/3/18 8:51
       Re: is it easy to turn a auto datsun 1200 coupe into a manual 1200rallycar 2011/3/18 10:37
       Re: is it easy to turn a auto datsun 1200 coupe into a manual ddgonzal 2011/3/18 19:08
