Re: reverse switch query vs overdrive switch
Quite a regular
From Olympia, WA, USA
I checked my 63A#2. It has three switches. They all switch on-off depending on gear selected. One is for Reverse (bullet connectors); One is Neutral (flat connectors); One activates in both 4th and 5th (flat connectors). I figure that I'd connect the latter to the Fasten Seat Belt light on the dash and change the wording to HYPERDRIVE.
Posted on: 2011/3/29 15:47
Edited by Ron1200 on 2011/3/29 20:11:43
"Horsepower... May you always have enough"
Subject Poster Date
     reverse switch query vs overdrive switch Anonymous 2011/3/26 9:14
       Re: reverse switch query vs overdrive switch Anonymous 2011/3/27 2:20
       Re: reverse switch query vs overdrive switch diymark 2011/3/27 2:39
       Re: reverse switch query vs overdrive switch Anonymous 2011/3/27 10:56
       Re: reverse switch query vs overdrive switch Ron1200 2011/3/29 15:47
       Re: reverse switch query vs overdrive switch ddgonzal 2011/3/31 8:31
       Re: reverse switch query vs overdrive switch Anonymous 2011/3/31 11:09
         Re: reverse switch query vs overdrive switch Anonymous 2011/3/31 11:18
       Re: reverse switch query vs overdrive switch revhead001 2011/3/31 12:42
       Re: reverse switch query vs overdrive switch Anonymous 2011/4/1 10:28
         Re: reverse switch query vs overdrive switch Anonymous 2011/4/1 10:35
