Re: Head fitment A12 on A15 block
estyre wrote:
as long as the head is a late model a12 head ,not off an early a12 with the dizzy up the front of the block
Correction
You CAN use the early [front distributor] head on the later cylinder block as the oil feed to the rockers is pumped directly up the correct head bolt hole in the cylinder head.
You can NOT use the later head on the early block because the early block feeds the rocker oil to a small vertical drilling at the side of the cylinder head gasket face. The cylinder head needs a corresponding drilling that feeds the oil across to the same cylinder head bolt hole as the later engines.
Since the newer heads do not have the drillings necessary to pick up the early engines oil feed, the rockers will not get any oil at all with predictable results.
Posted on: 2011/3/28 11:29
Love your Datsun.
Treat it well.
Subject Poster Date
     Head fitment A12 on A15 block sideways1 2011/3/27 11:26
       Re: Head fitment A12 on A15 block estyre 2011/3/27 14:08
         Re: Head fitment A12 on A15 block datski620 2011/3/27 14:14
           Re: Head fitment A12 on A15 block clyons8 2011/3/27 14:30
         Re: Head fitment A12 on A15 block Dodgeman 2011/3/28 11:29
           Re: Head fitment A12 on A15 block sideways1 2011/3/28 21:04
       Re: Head fitment A12 on A15 block sideways1 2011/3/27 19:31
         Re: Head fitment A12 on A15 block clyons8 2011/3/27 19:33
       Re: Head fitment A12 on A15 block sideways1 2011/3/27 19:54
       Re: Head fitment A12 on A15 block sideways1 2011/3/27 19:59
