Re: universal joint/ drive shaft HELP!
From Coondle, WA Australia
If it is the uni joints on the prop-shaft well they arent realy home servicable. You can pull them apart by removing the circlips , but you really need to goto a shop to have them replaced.
You could push some grease in and see if that helps.
By what you have said, i would have thought the diff centre as well.
Perhaps a wheel bearing?
Posted on: 2011/4/2 3:46
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Subject Poster Date
     universal joint/ drive shaft HELP! theflyingbra 2011/4/2 3:33
       Re: universal joint/ drive shaft HELP! reuby_tuesday 2011/4/2 3:46
         Re: universal joint/ drive shaft HELP! theflyingbra 2011/4/2 3:55
