Re: Clutch release bearing carrier
From Fremantle, West Australia
I think the problem may be the clutch fork rather than the bearing carrier
both the "C" and "D" carriers will work. I think you have the slightly longer "D" carrier which is good.
Did you use the B310 clutch fork with the big "hook" on the end or the straightish fork from the old 56 box?
Others have come unstuck by using the wrong cluth fork.
Posted on: 2011/4/28 0:24
Subject Poster Date
     Clutch release bearing carrier diymark 2011/4/27 11:34
       Re: Clutch release bearing carrier ddgonzal 2011/4/27 22:01
       Re: Clutch release bearing carrier Weekend1000 2011/4/28 0:24
       Re: Clutch release bearing carrier ddgonzal 2011/4/28 1:04
       Re: Clutch release bearing carrier diymark 2011/4/28 3:37
         Re: Clutch release bearing carrier ddgonzal 2011/4/28 3:45
         Re: Clutch release bearing carrier ddgonzal 2011/4/28 3:59
       Re: Clutch release bearing carrier diymark 2011/4/28 10:42
       Re: Clutch release bearing carrier A14force 2011/4/28 10:51
       Re: Clutch release bearing carrier ddgonzal 2011/4/28 19:07
