Re: tacho / Ballast resistor question
From Sydney
short answer is yes. You could identify which of those two wires has the +12v and simply connect that wire directly to the + side of your coil [as you are using electronic ign] and totally eliminate the loop cct for the ballast resistor.
Does your loom also have [typically black with red trace] wire that also connects to the +ve terminal on your coil which supplies the full 12 volts when engine cranking on startup. That cct bypasses the ballast resistor to make for a strong spark when starting the engine... Just thought I would ask.
Posted on: 2011/5/10 3:52
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Subject Poster Date
     tacho / Ballast resistor question edp 2011/5/10 3:42
       Re: tacho / Ballast resistor question benny 2011/5/10 3:52
       Re: tacho / Ballast resistor question edp 2011/5/10 3:58
         Re: tacho / Ballast resistor question ddgonzal 2011/5/10 4:36
