Re: Oil sensor and water temp thread size
The oil pressure switch threads is 1/8 BSPT (british standard pipe tapered). It screws directly into the oil pump housing.
If you fit a Tee connector, you can fit both the sensor and a separate guage. Tees are available in the usual auto supply stores such as Repco or Oreillys.
Posted on: 2011/5/23 8:30
Subject Poster Date
     Oil sensor and water temp thread size lightload 2011/5/22 15:08
       Re: Oil sensor and water temp thread size ddgonzal 2011/5/23 8:30
