Re: Dellorto Carb settings? Need some info on settings.
With accelator pumps in general, there are two factors:
1. Time of delivery. Perhaps a one second delivery is a good starting place.
2. Volume of delivery
There is both a pump jet and the rod/spring nut adjustment.
Pump jets for DHLA go from size 33 to 60. The size needed is not necessarily tied to the engine displacment but more on factors such as load and cam timing specs.
Posted on: 2011/5/29 1:28
Subject Poster Date
     Dellorto Carb settings? Need some info on settings. clyons8 2011/5/28 13:57
       Re: Dellorto Carb settings? Need some info on settings. ssskiwi 2011/5/28 23:07
       Re: Dellorto Carb settings? Need some info on settings. ddgonzal 2011/5/28 23:08
       Re: Dellorto Carb accelerator pump rod settings ddgonzal 2011/5/29 0:19
         Re: Dellorto Carb settings? Need some info on settings. clyons8 2011/5/29 0:27
           Re: Dellorto Carb settings? Need some info on settings. ssskiwi 2011/5/29 0:34
             Re: Dellorto Carb settings? Need some info on settings. clyons8 2011/5/29 0:46
               Re: Dellorto Carb settings? Need some info on settings. ddgonzal 2011/5/29 1:28
       Re: Dellorto Carb settings? Need some info on settings. ssskiwi 2011/5/30 0:21
