stock 1200 dyno'd
Motor Trend dyno'd a stock 1200 and found:
* Plugs were the wrong heat range, and had blistered
After putting the correct ones in:Quote:
The checks showed that the primary throttle functions of the [Hitachi] carburetion were right on. Idle on this car gave an air/fuel ratio of 14.1/1... Primary cruise...gave an air/fuel ratio of 14.3/1 ... The power phase, as expected, shot the air/fuel ratio 12.9
So far so good. Yet while the 1200 drove well, power was down above 4,500 RPM.
By adjusting the carburetor and distributor they increased power by 50%!!! without fitting extractors nor a larger carburetor.
Posted on: 2011/6/23 2:08
Subject Poster Date
     stock 1200 dyno'd ddgonzal 2011/6/23 2:08
       Re: stock 1200 dyno'd bakat 2011/6/23 4:31
         Re: stock 1200 dyno'd ddgonzal 2011/6/23 5:00
       Re: stock 1200 dyno'd bakat 2011/6/23 5:13
         Re: stock 1200 dyno'd D 2011/6/23 5:30
           Re: stock 1200 dyno'd ddgonzal 2011/6/23 6:36
       Re: stock 1200 dyno'd racer135 2011/6/23 9:38
       Re: stock 1200 dyno'd ddgonzal 2011/6/23 17:36
         Re: stock 1200 dyno'd D 2011/6/23 17:44
