Re: WA Rego with an a15 ,engineer cert ??
ITs not a ute you are building?
You best do a hybrid a12 with a14 crank
a12 rods bushed with a15 pistons with 77mm
bore you have 1434cc. Use Gemini flatop
slugs just check ACL catalogue. You will have
higher compression and less valve shrouding
with better effiency than a stock a15.
The lower rod stroke ratio will create better
torque/low end response much like Honda
does all its engines.
Posted on: 2011/7/4 10:21
Edited by D on 2011/7/4 10:39:54
Edited by D on 2011/7/4 10:40:20
Subject Poster Date
     WA Rego with an a15 ,engineer cert ?? estyre 2011/7/3 16:25
       Re: WA Rego with an a15 ,engineer cert ?? Anonymous 2011/7/3 21:30
         Re: WA Rego with an a15 ,engineer cert ?? Anonymous 2011/7/3 21:33
           Re: WA Rego with an a15 ,engineer cert ?? datski620 2011/7/3 22:50
             Re: WA Rego with an a15 ,engineer cert ?? Dundee1000 2011/7/4 1:05
               Re: WA Rego with an a15 ,engineer cert ?? D 2011/7/4 2:46
                 Re: WA Rego with an a15 ,engineer cert ?? Anonymous 2011/7/4 3:19
                   Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/4 4:48
                     Re: WA Rego with an a15 ,engineer cert ?? D 2011/7/4 7:13
                       Re: WA Rego with an a15 ,engineer cert ?? ddgonzal 2011/7/4 7:20
                         Re: WA Rego with an a15 ,engineer cert ?? Dundee1000 2011/7/4 7:48
                           Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/4 12:07
                             Re: WA Rego with an a15 ,engineer cert ?? clyons8 2011/7/4 12:15
                             Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/4 12:47
                               Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/4 14:47
                                 Re: WA Rego with an a15 ,engineer cert ?? dattoman_1000 2011/7/4 15:18
                                   Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/4 16:05
                                     Re: WA Rego with an a15 ,engineer cert ?? dattoman_1000 2011/7/5 0:52
       Re: WA Rego with an a15 ,engineer cert ?? perthute 2011/7/4 9:02
         Re: WA Rego with an a15 ,engineer cert ?? D 2011/7/4 10:21
       Re: WA Rego with an a15 ,engineer cert ?? DATUTE1 2011/7/4 10:49
       Re: WA Rego with an a15 ,engineer cert ?? dattoman_1000 2011/7/4 12:25
       Re: WA Rego with an a15 ,engineer cert ?? Dundee1000 2011/7/5 1:13
         Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/5 3:22
       Re: WA Rego with an a15 ,engineer cert ?? dattoman_1000 2011/7/5 11:49
         Re: WA Rego with an a15 ,engineer cert ?? levey 2011/7/5 11:54
           Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/5 12:00
           Re: WA Rego with an a15 ,engineer cert ?? levey 2011/7/5 12:05
           Re: WA Rego with an a15 ,engineer cert ?? boondy 2011/7/5 12:25
         Re: WA Rego with an a15 ,engineer cert ?? datski620 2011/7/5 12:01
           Re: WA Rego with an a15 ,engineer cert ?? datski620 2011/7/5 12:27
       Re: WA Rego with an a15 ,engineer cert ?? datski620 2011/7/5 12:30
         Re: WA Rego with an a15 ,engineer cert ?? boondy 2011/7/5 13:06
       Re: WA Rego with an a15 ,engineer cert ?? levey 2011/7/5 13:13
       Re: WA Rego with an a15 ,engineer cert ?? Dundee1000 2011/7/5 13:17
       Re: WA Rego with an a15 ,engineer cert ?? old_school 2011/7/5 15:11
       Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/5 16:22
         Re: WA Rego with an a15 ,engineer cert ?? estyre 2011/7/5 16:23
