Stanza Front End in 1200
From Mandurah, Western Australia
This has been discussed a bit lately, but I an after some advice on what inserts work well with this setup.
I have The stanza front suspension in my 1200 with a CA conversion. I am running Stanza Struts, un shortened with SSS Stanza Springs. I have a heavy duty sway bar fitted also.
The present ride height of the vehicle is good, but the dampening qualities of the front end leave a bit to be desired.
I am running 14 inch rims with 185/60 rubber. The spring perch is only just above the tyre, so moving it further down the strut is not an option.
The struts are original, with the original oil, will putting in a replacement Stanza replacement cartridge (Pedders 8722 Comfort Gas Cartridge) net possitive gains, or is there any thing else worth considering.
Cheers
Posted on: 2011/7/17 14:13
Subject Poster Date
     Stanza Front End in 1200 old_school 2011/7/17 14:13
       Re: Stanza Front End in 1200 lightload 2011/7/18 2:01
         Re: Stanza Front End in 1200 1200rallycar 2011/7/18 2:08
       Re: Stanza Front End in 1200 DatsAndy 2011/7/18 2:04
         Re: Stanza Front End in 1200 old_school 2011/7/20 12:31
       Re: Stanza Front End in 1200 coxsteve 2011/7/18 12:08
       Re: Stanza Front End in 1200 old_school 2011/7/18 15:09
         Re: Stanza Front End in 1200 PIGDOG 2011/7/18 23:10
