Re: Performance coil, which one do I need?
when o connect up the new coil I just dissconnect the ballast and make it redundant?
If you have fitted a 12V EI coil (high-energy coil), add a jumper wire as shown in red:
Or you can:
1. physically remove the resistor
2. connect the harness wires to the coil and distributor
Posted on: 2011/7/21 1:41
Subject Poster Date
     Performance coil, which one do I need? yz1975 2011/7/20 23:50
       Re: Performance coil, which one do I need? ddgonzal 2011/7/20 23:54
         Re: Performance coil, which one do I need? yz1975 2011/7/21 0:10
           Re: Performance coil, which one do I need? ddgonzal 2011/7/21 1:13
             Re: Performance coil, which one do I need? ddgonzal 2011/7/21 1:31
               Re: Performance coil, which one do I need? ddgonzal 2011/7/21 1:41
                 Re: Performance coil, which one do I need? yz1975 2011/7/21 12:07
                   Re: Performance coil, which one do I need? estyre 2011/7/21 14:30
                     Re: Performance coil, which one do I need? ddgonzal 2011/7/21 19:56
