Re: CA18det with stock tacho
From Melbourne, Australia
to emulate the 1200 wiring style for tacho i would need to run the fat blue wire from the S13 loom (which powers coils) past the back of the tacho, dont really wanna do that
tried this, test drove it today... works a treat! very happy
i just cut into the wire going to the coils (10 or 15 amp) but i used a 25amp rated wire (so that i wouldn't be adding resistance to the circuit by extending the length), by joining that in i extended the blue wire, ran it past the back of the stock tacho in the same way the original one did and then back to the other end of where i cut it, effectively extending the blue coil power wire from the S13 loom.
Posted on: 2012/6/10 7:54
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     CA18det with stock tacho 1200rallycar 2011/8/10 12:51
       Re: CA18det with stock tacho PIGDOG 2011/8/10 13:19
         Re: CA18det with stock tacho 1200rallycar 2011/8/10 13:27
           Re: CA18det with stock tacho 1200rallycar 2012/6/10 7:54
       Re: CA18det with stock tacho lamb_daiquiri 2011/8/10 13:46
       Re: CA18det with stock tacho old_school 2011/8/10 14:02
         Re: CA18det with stock tacho 1200rallycar 2011/8/10 14:05
       Re: CA18det with stock tacho lamb_daiquiri 2011/8/10 14:16
       Re: CA18det with stock tacho Anonymous 2012/6/11 2:00
         Re: CA18det with stock tacho 1200rallycar 2012/6/11 2:06
           Re: CA18det with stock tacho Anonymous 2012/6/11 2:25
