Re: Changing head gasket on ca18det
From MOOROODUC. Victoria
has the timing Belt been replaced in living memory?
It's not an expensive item and u will have to remove the camshaft gears so if you have the radiator out then it can be done thru the front.
I have had good success with lifting the car up and dropping out the engine, g/box, cross-member , etc (remember to disconnect the steering bar under the engine)
Posted on: 2011/9/8 10:31
Subject Poster Date
     Changing head gasket on ca18det datto13b 2011/9/8 4:00
       Re: Changing head gasket on ca18det Anonymous 2011/9/8 4:26
       Re: Changing head gasket on ca18det trb012 2011/9/8 5:50
         Re: Changing head gasket on ca18det datto13b 2011/9/8 10:10
           Re: Changing head gasket on ca18det demacoz 2011/9/8 10:31
       Re: Changing head gasket on ca18det datto13b 2011/9/8 22:49
