Re: distributor setting
From Ringwood, Melbourne, AUS
what you need to do is find a reasonable setting that will allow you to start it, as the Rev says 10-12 BTDC is prob OK.
Then you need to set max mechanical advance to a suitable setting (make sure the vac advanve tube is disconnected and plugged), from memory I used to run approx 35 BTDC, all in by 3500rpm.
Unless you have had your dissy re-curved, you will probably find that you won't be able to get both the correct max advance and a suitable idle advance together..
Posted on: 2011/9/10 2:34
Deano
Subject Poster Date
     distributor setting nismo1 2011/9/9 16:29
       Re: distributor setting revhead001 2011/9/9 22:18
         Re: distributor setting ssskiwi 2011/9/10 2:34
       Re: distributor setting nismo1 2011/9/10 8:18
