A SERIES ENGINE REBUILD KITS & ENGINE PARTS
From sydney.nsw
a10/a12/a14/a15 "rebuild kits" with a15 cast dish pistons, a14 hi comp,a12 flat top/rings/conrod,mains,cam bearings/gaskets/timing kit. can make up kit to suit your sizes you need. starting for $450.00.
can also do separate items. if required
also got a set of NEW ross forged a15 78mm flat top pistons with pins & clips &
valve reliefs (30mm c/h) & total seal race rings.custom made.
also a s/hand set of ross forged flat tops(with valve reliefs)77.5mm a15 on rods(polished & shotpeened) & rings(used totalseal, be ok for re-use)(slight crown damage & skirt,but still can be used no problems.
also a15 NEW 77.5mm flat tops (no reliefs) 29mm c/h cast pistons/rings/buttons, 18mm bushed floating rods to suit.
also got engine parts; heads/cams/cranks/ sumps/rockers .all other parts as well.
"i can also build for you or build yourself"
pm if interested. cheers
jpg  engine kits a15.jpg (62.90 KB)
9764_4ea936c25e889.jpg 294X221 px
Posted on: 2011/10/27 11:44
Edited by bige on 2011/10/27 12:02:49
Edited by bige on 2011/10/27 12:06:17
Edited by bige on 2011/10/27 12:07:35
Edited by bige on 2011/10/31 5:31:25
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Subject Poster Date
     A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/10/27 11:44
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/10/29 14:47
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/10/31 5:32
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/11/4 10:54
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/11/30 7:21
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/12/12 0:01
         Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS aw 2011/12/12 6:54
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS DISMO 2011/12/12 10:36
       Re: A SERIES ENGINE REBUILD KITS & ENGINE PARTS bige 2011/12/12 11:24
