Re: Run without Carburator Anti Diesel Valve
Sumith, it sounds like your engine has more than one problem.
The spark timing should be set to a known value (like 10 BTDC) instead of just guessing, backing it off, advancing it forward. Because:
* static timing is the foundation of engine tuning. It should not be guessed at.
* it could be affecting the other problems. Once you have all the problems fixed, then backing it off, advancing it "by ear" would be OK for fine tuning.
I recommend you get a repair manual, RPM gauge and dwell meter (new $25 USD) -- and do it yourself. Then you'll know how it's done and won't have to rely on a mechanic who so far hasn't solved your problems. Just take it one step at a time, until all the settings are correct and the problems solved one at a time.
Posted on: 2011/12/7 1:28
Edited by ddgonzal on 2011/12/7 1:45:46
Edited by ddgonzal on 2011/12/7 1:48:26
Subject Poster Date
     Run without Carburator Anti Diesel Valve Sumith 2011/12/6 8:40
       Re: Run without Carburator Anti Diesel Valve a12datto120y 2011/12/6 9:19
         Re: Run without Carburator Anti Diesel Valve Sumith 2011/12/6 15:25
       Re: Run without Carburator Anti Diesel Valve bakat 2011/12/6 18:30
       Re: Run without Carburator Anti Diesel Valve ddgonzal 2011/12/7 1:28
         Re: Run without Carburator Anti Diesel Valve Anonymous 2011/12/7 1:47
         Re: Run without Carburator Anti Diesel Valve Sumith 2011/12/7 4:08
           Re: Run without Carburator Anti Diesel Valve Anonymous 2011/12/7 4:12
             Re: Run without Carburator Anti Diesel Valve Sumith 2011/12/7 7:43
               Re: Run without Carburator Anti Diesel Valve ddgonzal 2011/12/7 7:51
                 Re: Run without Carburator Anti Diesel Valve Sumith 2011/12/9 4:48
       Re: Run without Carburator Anti Diesel Valve edp 2011/12/7 3:58
       Re: Run without Carburator Anti Diesel Valve edp 2011/12/10 19:32
